i have a 97 mm 700 and want to put a 4" riser on. a pivot one preferred and ill need longer cables does anyone know where i can look for a good deal?
thanks
check out used parts. look for mtn machines. others will need to give you the model # but I believe the viper throttle(?) cable is longer, and will work for machine. same with brake cable. I am unsure of the year/model that will help. The oil cable can usually be re-routed over the air box. there is a slot/gap under the filter that it can go through. makes the airbox harder to get out, but the oil cable is evil to replace. soory about not having model numbers.
I sell everything you need.If your interested i have a deal on a Rox 5" pivot riser for $75.If you want a complete setup with riser,brake line,oil,gas cables it would be $195 shipped.Heres some links.Any questions let me know.
