language barrier? if your holding the orange wire and its not hooked to anything, you will have no spark at the plugs. if the orange wire has been spliced/repaired and its able to shock you, its probably grounding out somewhere. this would be real hard on both the cdi unit as well as the stator. that voltage is supposed to go to the coils, not you, or anywhere else for that matter. again, is the orange wire connected to a coil or just laying there for you to grab while your turning the engine over?
