panshovel1966
Well there u have it, just killed my 95 Vmax i had leaned out to much and the kid took it out for a spin, he then came back on one cylinder, yap compression gone, i Though there was a hole in the piston but no rings where welded to the side of the piston on the exhaust side so now got to wait till the dealer opens tomorrow to get a new piston and rings, also owne out the cylinder hopfully!! then try again.... merry christmas son.
Pan
Ride Free!
Pan
Ride Free!
hereismylife
that sucks.....
keep her stock and clean. run for 10k easily
no1chevyboy
what did you do to lean it? is this the frosty carb one?
panshovel1966
Ya thats the one !!!
i want and set the air screws back to stock settings, disrigarding the instructions for the pipes . so i paid for it lol
no1chevyboy
your pilot scews shouldnt have done that
panshovel1966
Correct me if i am wrong but if you have a leaner mixture then youre engine runs hotter and if you open up the air screwyou are leaning it out wright?
no1chevyboy
what you say about lean mixture is right, but the pilot screw on bottom of carb is for the idle circuit and on your carb its a fuel screw, opening it would give you more fuel closeing it would give you less fuel, doing either would mostly effect idle
TRUE BLUE SINCE 1980
Just wondering if you have that GYT head gasket in there (the short one that was used to boost compression? If you do go back to the stock gasket.
The same thing happened to my 600-twin when the kid rode it. it It had about 5000 miles on it , those motors are trying to shack themselves apart all day long...... but it will be good to go with some new parts in there.
hereismylife
TRUE BLUE SINCE 1980 said:Just wondering if you have that GYT head gasket in there (the short one that was used to boost compression? If you do go back to the stock gasket.
What are you asking or trying to say?
There was a GYT proformance kit sold back in 1986 that was part of a clutch kit... it had a shorter head gasket that could have been installed by a dealer.
I was just wondering if this motor may have had that done , I think that is what gave me problems when the younger kid took over the sled. With the gas today tthat motor does not like to run at half throttle with the extra compression of that short head gasket.
