Vmax 600sx -97 running bad?
could be clutching issue sounded like loaded motor, not back shifting, primary spring broken? never really sounded clean, it sounded like it was loaded the whole time. jmo but you were breaking trail?
Yeah I was thinking of that too, some issue with the clutching. I don't know anything about clutching so I will probably hand it over to some yamaha mechanic who can take a look. How much do you think it would cost to fix it if I hand it over to some mechanic?
Was out on the lake, about 15 inches of snow on the video.
Went out and took some pictures, sorry if they are too big.
your primary looks alittle dirty and some rust, id clean that up. your belt looks a little low in secondary.
check your compression. we just had one in at work that ran the same and it turns out that there was heavy scoring on the wall cousing it not to clean out.
