00SRXWHERRY
Just as is says I have a Bender helix in my SRX that I have been rebuilding and tring to ID the previous owners parts that he had in it. The sled has a Bender helix and the only Iding mark on it is someting that appears was engraved is a 20-70. So for all you clutch guys is this a part number or the actual helex angle. Other additional Clutch info is 15.6 rollers, Heel Clickers W/ 8 washers on the heel, bolt and washer in the middle, and a bolt on the tip W/ a H/C red primary. The senconday is a white spring ran at 0 deg.. So any info will help ID this helix. And yes it is another clutch question sorry.
Bender 2070 = 47/43
00SRXWHERRY
Thank you
