clunking sound when breaking
snopax
Wisconsin
Noticed a metallic clunk when applying the brake, just as she comes to a stop.... Any ideas? Braking seems normal, if not a little tight. Has a viper reverse installed. 00 SRX
grab the brake rotor and see if it wiggles forward and backward on the jackshaft??, sometimes the keyway gets loose and they will clunk at slow speeds, drives ya nuts. best fix is to either replace the rotor or install a aftermarket alum. brake hub.
