viper front end in srx
avbrando
WESTERN WISCONSIN
just wondering if it is possible to use the srx trailing arms with modified viper shocks, radius rods and tie rods or will the spindle angle be incorrect?
You can do the swap but you will need the Viper spindles as well or you end up dropping the nose about 3/4" or more. I am not sure if the rod ends on the control arms are the same where they mount to the bulk head also - use this link to go in and look at all the parts for both sleds to see if there are any visual differences with the control arms.
http://www.yamaha-motor.com/sport/m...L2hvbWUuYXNweA==/Parts Catalog/starthere.aspx
Viper Front End On An Srx
I have this on my sled. I used the aftermarket wide kit set at 42 inch ski stance. I used Viper trailing arms with matching Viper spindles. The Viper shock upper mount is different. There was a guy on this forum selling the modified upper mounts ( BETHEVIPER) which work well. Overall a good worthwhile swap out.
