another helix question
NewSRX'R
Michian
What is the all around 50 % trail / 50 % lake racing best multi angle helix to run on a stock srx? Any ideas?
not really a said certain helix, because it all depends on what primary weights your using as to the helix. A good rule of thumb to follow is if your using a aggressive primary weight your going to use a smaller helix. if you use a less aggressive primary weight your going to use a bigger helix.
example, the 8dn20 weights on the newer srx's are a good weight, not real aggressive but nice shift, you use a fairly aggressive helix with them to get what your asking about. The other side of the coin is for example a set of 8bu weights, very aggressive weight,youll use a much smaller helix then you would with the 8dn weight set up described before.
so you see there isnt really a answer for your question till youd know which primary set up your going to run.
