john7459
white plastic tunnel protectors that run the length of the sled.
For some reason my track is rubbing progressively on them, at the front there is thick black rubber scuffing all over but its reduced the further you go towards the rear heat exchanger.
There are damage marks on the track from where it is rubbing. Thoughts on the cause?
Shocks are both good still. 01 SRX no mods
tracks too loose and growing, it always grows themost right under the gastank area.
john7459
that makes perfect sense, thanks for the quick reply!
