I'm serviceing my engine in my SRX 700 for the first time. I did a pressure test, engine was room temperature, and i got around 65 PSI on all cylinders. I know that not all testers are the same and could give different values, but shouldn't i be getting 120-140 PSI? The tester is brand new, never been used. I pulled 4-5 times and WOT. Tried both with and without spark plugs in the two other cylinders, gave the same reading.
I also disassembled the power valves, however i could not remove them from the cable. What's the trick? Didn't want to pull to much on the cable. The middle valve had a snapped cable, valve seemd fine no pull trough, so i guess i just have to replace the cable.
