Coil Pack
yamahaguy_83
Flint, MI
I believe I have a bad coil on one cylinder of my 97 Vmax 700 as it doesn't seem to be getting any spark. The other two cylinders are fine. Is there any way to check to check it other than swapping it out with a known good one?
Also, if I have to replace it, would a 98 or 00 Vmax set be the same or did they change them later on. I'm pretty sure the 98 would be fine but I'm not sure much beyond that.
