Fleury_XLT
My friend SRX seem to have a big problem. We have checked and cleaned all the carburator, changed intake gasket, the engine is freshly rebuilded, new plugs.... The problem is : at idle, everytings is good, but the acceleration is poor and over 5-6k rpm, there some big back fire (I can see the fire out of the 3 carburators) and big backfire out of the exhauts... Forget to say, new gasoline was used !
Any Ideas ?
Any Ideas ?
CNYSRX
I know this is going to sound goofy, but check the secondary clutch. My kids have a Polaris that we were just having the same problem with. We Cleaned the carbs, checked compression, electrical, and everything we could think of. Come to find out it was the secondary clutch!
bluewho
Is your throttle cable to tight?When you say you cleaned the carbs what did you do explain.It could be the tps
Fleury_XLT
I've cleaned air jet, pilot, main, ajust the fuel screw to 1 7\8 turn, Every parts where cleaned with brake cleaner
Fleury_XLT
CNYSRX said:I know this is going to sound goofy, but check the secondary clutch. My kids have a Polaris that we were just having the same problem with. We Cleaned the carbs, checked compression, electrical, and everything we could think of. Come to find out it was the secondary clutch!
What do you means with secondary clutch ?? Backfire could be reliated with that ?
bluewho
Does the moter sound like a honda on the rev limiter when on the gas?
Fleury_XLT
The engine sound like he want to get out of the cab lol, no rev limited, just BIG backfire with fire out of the carbs !
I am guessing you are flooding it due to sticking or inproperly adjusted floats or sticking starter jets. Too much fuel getting into the engine.
bluewho
Holy smoker tabernack!
Now that made me laugh !!!Fleury_XLT said:The engine sound like he want to get out of the cab lol, no rev limited, just BIG backfire with fire out of the carbs !
Fleury_XLT
Could it be an electrical problem causing there pre-detonation ?
doesnt seem like a electrical problem ....
what color are those plug ....it will give a a good direction if its very lean or piggy ritch
did u forget to put back the reeds ......................
Fleury_XLT
modsrx said:what color are those plug ....it will give a a good direction if its very lean or piggy ritch
They are not colored yet, they are brand new, and I don't wan't to let the engine run for to long
Fleury_XLT
modsrx said:did u forget to put back the reeds ......................
No they are in place
its gonna be hard but maybe mr viper got a idea about it .....to me its seem like its very very lean out in midrange for someone reason .........
780srxgeorge
check your YPVS motor.i just got done working on 02 viper & the 1 cable was off track & in another track so 2 cables in same spot it ran ok at idle but punch the throttle fall on it's face & back fire did the same as you did on carbs & every thing in between.yeap check the ypv motor this sled runs good now.good luck
YAMMIEGOD3:16
WHENEVER YOU HAVE A BACKFIRE OR A EXPLOSION SORTA -A SPEAK, THATS A PROBLEM WITH SPARK, A COIL, A CDI, A STATOR, SOMETHING IN YOUR INGINTION. CARBS ARE WORKING FINE, THATS FUEL GETTING OVER BURNED OR A INTIMIT,IN SPARK CAUSEING A KICK BACK. 3:16 (yammie tony)
Skidooslayer687
YAMMIEGOD3:16 said:WHENEVER YOU HAVE A BACKFIRE OR A EXPLOSION SORTA -A SPEAK, THATS A PROBLEM WITH SPARK, A COIL, A CDI, A STATOR, SOMETHING IN YOUR INGINTION. CARBS ARE WORKING FINE, THATS FUEL GETTING OVER BURNED OR A INTIMIT,IN SPARK CAUSEING A KICK BACK. 3:16 (yammie tony)
X2,
when my sled wasnt firing on the middle cylinder, I'd always get a buildup of raw fuel and a backfire... Could definately be electrical dont rule that out... You might want to check the condition of your reeds to after having the backfires
