I'm just wondering if the codes for the 00 SRX and the 01 SRX are the same? My SRX is giving me 1 long and 2 short and it seems to come off and on depending on how much throttle i'm giving it.
WNYViper
hmm, they have different ones in the Tech section, but it doesnt mention a "long, short, short"...
http://www.totallyamaha.com/snowmobiles/aaTECH/codes/SRXWarningCodes.htm
01 Specs, has a 3 blink code, but not a 'long, short, short'
http://www.totallyamaha.com/snowmobiles/aaTECH/codes/FaultLocationCodes.htm
Viper Specs has a 3 blink, 'long, long, short' for TPS sensor, might be something to look at...
http://www.totallyamaha.com/snowmobiles/aaTECH/codes/2.jpg
Anyone have a deffinate yes, no or otherwise??? Kinda looking to get this solved asap.(Without sounding like a peckerhead) I'm getting hounded to go for a ride tonight.
There isnt a code as the blink sequence you describe, there is a 3 blink on opposite for the TPS sensor on the carb rack. The sequence for it is 4 seconds long and has 2 long then 1 short then repeat.
tofastSRX
Netfrog I Think You Should Fireit Up On The Stand A Watch The Blink Sequence Again Buddy.
