retro-sled
can it be done? and if so does anyone carry block off plates to carry this out? thanks
why would you want to do that anyways???
retro-sled
swapped to flatslides and don't trust the oil pump .. 1 less thing i need to worry aboutnosboy said:why would you want to do that anyways???
Mysledblows
Doesn't the tach feed come off the oil pump drive? When I did my 91. I just looped the lines coming off the pump and added a little grease to the tach drive ever year so that it was lubed and kept working. If I didn't lube it, the tach would do some funky things. Ran it for a few years that way.
srv540
I put a set of flatslides from a vmax 600 on my Phazer, with a small mod i got my oil injection working these pics show the basic idea of how i did it, Cable is ziptied into place till i can fab a bracket zero problems with it yet!
How well does it run? Did you feel any improvement? I have heard of this mod. Is it worth all the trouble?
retro-sled
how sure getting right amount of oil? coming off arctic cats were had tons of reliability issues ( main reason for going yamaha)
srv540
well i took mesurments from the stock setup for the oil pump cable, and throttle reponce is better, i had to rejet new pilot and adjusted the needles but i would say its worth it!
I guess I need to find a cheap set and try.srv540 said:well i took mesurments from the stock setup for the oil pump cable, and throttle reponce is better, i had to rejet new pilot and adjusted the needles but i would say its worth it!
retro-sled
is the oil injection pump on the vmax 600 different? wondering as need new cable anyways just get one for it instead
srv540 said:I put a set of flatslides from a vmax 600 on my Phazer, with a small mod i got my oil injection working these pics show the basic idea of how i did it, Cable is ziptied into place till i can fab a bracket zero problems with it yet!
Are you getting the same pull on the cable as the stock set? I just received my set of flat sides. What Needle and clip position, Main and Pilot jets are you using? Just looking for a starting point.
srv540
yup same pull, I am running 150 mains needle stock position and using 47.5 pilot jets, but i just bought a psi pipe last night so will jet up a bit, your carbs from a 600 vmax 38mm right?
96 XT600 with 52.5 pilot, 162.5 mains
