nitris223
Any one know where you can buy KYB shock parts for a 2002 SXR 600. I took my shocks in for a recharge and oil change and when they put the needle in to discharge the shock they said the bladder blew out. It is inside the threaded insert with a phillips screw. Lucky I had the old shocks still kicking around and the bladders were still good in them. The guy that rebuilds the shocks said it is only the Yamaha shocks that he has seen this happen to. Yamaha said you can not but the part , I would have to buy new shocks.
call Wild Wood Yamaha in Winnipeg MB they are the rebuild center for yamaha shocks
nitris223
Thanks Darv. Wouldn't happen to know the number by chance. I guess I could do a search online. Any buddy specific I should talk to there.
Deycore in Minnesota is very good with any snowmobile shock. Has everything to fix, modify or build a shock from scratch.
shock repair
I always talk to Paul German he is the owner he will get you fixed up, No do not have number off hand
