96 Yamaha Phazer II no spark
Scootertrash
MN
Need some help tracking this down. Kill switch tests out OK (continuity when in the off/down position, no continuity when up/on. TORS seems to be working properly ( if I hold the pivot pin in place and then press the throttle I get continuity. Press on throttle without holding pivot pin in place no continuity.) A schematic and/or some specs would be great.
Thanks guys!!
Scooter
check the wireing coming out of the motor. some times it breaks in the rubber isolator. otherwise it could be a harness rubthrough or bad ground.
I'm going out to do some more testing right now. The guy drove it on the trailer last spring, so it worked then. I can't remember if the kill switch was off when I dragged it off of the trailer or not. The gas was bad too so I never really tried to start it that hard.
Will post an update later.
