Hello every one, I was wondering if I could put a Yamaha mountain skis from a Nytro under my Yamaha viper with out doing some big changes ?
dirtjumper895
Yes, you can. To make it easy, get the ski hardware from the Nytro (bolts,collars,nuts). You are going to have to cut down the collars, because the viper spindle is slightly wider than the Nytro's.
Truckkid42
yea, thats what i have under my viper. i have apex mountain skis on my viper. it is an incredable difference. easy as heck to put on. if you don't get all teh hardware, just go to homedepot, thats what i had to do, and it was about 8 dollars for everything.
Viper_Jim
Are these the same skies that come stock on the 05-06 Mtn Vipers as well? I was considering putting a set of them under my sled but if the Nytro ones are better I will get those.
All saddleless Yamaha Mountain skis are the same (except for color of the grab handles), after 2005-ish regardless of the model. the only difference is which mounting hard ware is required for installation.
I have a set for sale in the classified section right now. They have the hardware to mount an Apex/ Attak. Just have to go to the fiche and procure whatever hard ware you need to mount on your particular model sled. Mountain skis are wider than stock and require spacers.
