SRX no fuel, now no spark...8 volts at ignition and not running
sledbuttrob
Gorrie, Ontario
I thought I lost my fuel pump last week. Now I think I've lost my mind. This thread,
http://www.totallyamaha.net/forums/showthread.php?t=76217&highlight=experts
I poured a little fuel down the cylinders just to get it running to get it in the shop. Wouldn't start. No spark.
Ok, so I dragged her in. Started looking for power at the ignition switch. Hooked up my meter to the ignition switch connector and I have about 8 volts before I pulled it over. Tried another meter. The same. How can that be? There is no battery.
If It Started With Gas In The Cylinders It Has Spark ? Pull The Lines Of The Carbs And Pull It Over See If Fuel Pissis Out The Lines
Would not start with gas down the cylinders, which I always had to do when it sat for more than a couple of days.
Fuel is pump not pumping fuel. Fuel pump looks OK. Fuel is getting to pump. Now no spark too.
