Idle Adjustremnt Screw and Tors Switch
snopax
Wisconsin
Ok, so I made the mistake of disassembling the TORS button from the idle air adjustment screw and I can not get them back together. Anyone know any tricks on how to re-assembly this thing? If not I think I'm just going to buy a bolt and lock nut, spring load it and use it as the adjustment.
Nevermind, figured it out.... Just a heads up, do not dis assemble the idle set screw. The bracket needs to be removed to get it back together and it is almost impossible to tighten down the shoulder screw that holds the assembly together.
On a side note, does anyone know of a better solution? I'd still like to just use a spring loaded bolt and lock nuts, I'm afraid they would rattle free over time. Anyone tried this?
Leave it stock,, I adjust mine all the time to compensate for ambient temperature which changes one day to another by 30 degrees affects jetting......... Takes 15 seconds.....
