smokeyrider05
i have a 99 srx 700 with single headlight style. my question is will the newer dual headlight style dash and headlight bolt onto my older 99 single headlight style hood???
has any one done this? is it do able?
thanks,
thanks,
super1c
Super Moderator
Do a search tons of info on this, lots of guys have done this but its a fair bit of work. Here is a start. http://www.totallyamaha.net/forums/showthread.php?t=63073&highlight=dual+headlight CCC
smokeyrider05
besides electral. will it just bolt right into place with no problems?
RIVERRUNNER
As long as you get two bulb gauge pod and wind shield. I don't see why not!
victoryismine
It works just fine. You just need the new gauge pod, headlight and windshield. I use 35 watt bulbs in the new headlight, and haven't had any problems. I also replaced the taillight with an LED one so that saves on wattage.
smokeyrider05
ok cool, thanks guy's. i'm now looking for a 2000 srx guage pod, headlight and windshield
Argento102
smokeyrider05 said:ok cool, thanks guy's. i'm now looking for a 2000 srx guage pod, headlight and windshield
Doesn't the stator need to be changed from the 100w to 300w unit?
victoryismine
Argento102 said:Doesn't the stator need to be changed from the 100w to 300w unit?
I would change the stator if I was going to run two 55 watt bulbs. That's why I just run the 35 watt bulbs.
