mikeydoodle
im having trouble with my 03 viper. when i give on it off idle (around 3/4 to full throttle) it bogs down and the takes off. but when i rev it up till the clutch almost engages and full throttle it it has no bog. is this normal or is something out of adjustment?
super1c
Super Moderator
Hi and welcome to the site!!! Check this out first. Sounds like its dirty carbs!!! You will find how to do this and a ton more. CCC http://www.totallyamaha.net/forums/showthread.php?t=76637
If after you clean the carbs still have trouble do a search on fuel screws.
Also, make sure your throttle cable is adjusted properly.
SX600abuser
Fatten out the fuel screws. Start with a half turn out, then go in 1/4 turns from there if needed. If your carb was dirty, it wouldn't idle.
mikeydoodle
thanks guys ill start by cleaning the carbs (never cleaned them) and then adjust them.
mikeydoodle
cleaned the carbs and still bogs. i put the choke on the first notch and the bog went away. richened idle screw to 2 turns from 1.5 and the bog almost cleared up. what would cause the lean condition? im running chevron 94 does this gas have ethanol in it and would the ethanol cause it to run lean enough to bog?
staggs65
sounds like the carbs still need some cleaning. if you don't find anything maybe up a pilot size
pipdviper
Check your drive belt as well. A worn belt falls too far into the clutches and makes the sled pull out in "high" gear if that makes any sense??
staggs65
good pointpipdviper said:Check your drive belt as well. A worn belt falls too far into the clutches and makes the sled pull out in "high" gear if that makes any sense??
yamaha721sxv
What do you mean by "fall out"staggs65 said:good point![]()
