Free play in secondary???
SRX RIDER
Central PA
I was checking things out on the Viper tonight and noticed that I have a slight amount of free play in my secondary clutch. This would be side to side on the jackshaft. I can move the entire clutch in and out on the shaft a few thousandths of an inch. there are shims/washers between the mounting bolt and helix where I can see the play. Is this normal or is something out of wack? Dumb question, but my knowledge is limited and I have to ask somewhere! :oops:
Thanks!! I just wasn't sure because my old SRX is tight. But then again that's a much different setup.
