Want to get rid of oil injection
raptorman2fast
SD
How can I disable/remove the oil injoction feature on my 97 SX 600? I want to start using premix and not worry about oil pump failures. Any thoughts/suggestions?
Remove and plug the hose that comes from the oil pump to the fuel pump. Not sure you want to do this tho. I thot the oil pump also directly pumps a small amount of oil to the crank bearings. I could be wrong tho
