lowmilevmax
I did some searching but couldn't find the answer I was looking for. I just bought a used 3/4 " studded track for my 96 XT and from what I read I should install tunnel protectors. first question is where exactly do they go? middle or outside. Second question is how would the track hit the tunnel with the heat exchangers running down the tunnel, Third question is does anybody have pics of their protecters.
thanks Jason
thanks Jason
bluebandit98
the tunnel protectors r suppose to run right above the trck windowsso when the suspension bottoms out it his them an stops instead of tearin into ur tunnel an so they dont tear the lugs on th etrack apart from what i know
lowmilevmax
but the heat exchangers run above the windowsbluebandit98 said:the tunnel protectors r suppose to run right above the trck windowsso when the suspension bottoms out it his them an stops instead of tearin into ur tunnel an so they dont tear the lugs on th etrack apart from what i know
YamahaGuy-1
I just put mine in last night so it is still fresh in my mind. When you look up under the back of the seat you will see the heat exchanger that goes across the back of the sled, you also have the two long ones that run to the front of the tunnel, and yes they are above the windows in the track. In between the rear heat exchanger and the long ones there is a little ramp type thing on each side that is fastened on with four rivets each. You take out the two back seat bolts and prop up the back of the seat, then you drill out those four rivets that are holding on the ramp shape thingys. You then have to pound the remainder of the rivets up through from the bottom and fish them out from under the seat. Then take the two new longer protectors and fasten them using the two front holes from the ones you just took off. Then you drill the other holes for the remaining rivets, this is where it gets tricky because you are actually drilling into a little tab on the bottom of the rear heat exhanger!!! I made my own drill bit stop and clamped it on the bit so that I would not go too deep and get into the coolant reservoir.
The protectors have been discontinued by just about every company but you can still find them on ebay and such. I just did a search and found these ones on ebay. Go to ebay and in the search box type in item # 300489769378 and you will find some yamaha protectors. The ones I got were made by bender but were the same exact thing, only problem was mine did not include all the rivets so I just put two in the front holes and two in the back and didn't worry about the middle ones. Also the ones I got had really good directions with them which I still have so if you find a set and need a copy of the directions as to how they go on let me know.
lowmilevmax
is that all the protection needed?YamahaGuy said:I just put mine in last night so it is still fresh in my mind. When you look up under the back of the seat you will see the heat exchanger that goes across the back of the sled, you also have the two long ones that run to the front of the tunnel, and yes they are above the windows in the track. In between the rear heat exchanger and the long ones there is a little ramp type thing on each side that is fastened on with four rivets each. You take out the two back seat bolts and prop up the back of the seat, then you drill out those four rivets that are holding on the ramp shape thingys. You then have to pound the remainder of the rivets up through from the bottom and fish them out from under the seat. Then take the two new longer protectors and fasten them using the two front holes from the ones you just took off. Then you drill the other holes for the remaining rivets, this is where it gets tricky because you are actually drilling into a little tab on the bottom of the rear heat exhanger!!! I made my own drill bit stop and clamped it on the bit so that I would not go too deep and get into the coolant reservoir.
YamahaGuy-1
That is what I was told was needed and those are the only protectors I have ever seen available. Any search I have ever done has turned up those and those only.
STEERJOCK
Im doing the same thing....On my brothers SRX 600, he has tunnel protectors that run from the rear heat exchanger to the front, but thats were my top exchangers are...Should I worry about those top protectors or are the top heat exchangers enough?
But yes, as stated above, he is correct with the front and rear protectors, especially the front, they are needed the most!
you dont need tunnel protectors on the xt... the heat exchangers do that for ya ..what you do need is heat exchanger protectors on the rear heat exchanger! as yamahaguy has stated!
lowmilevmax
just ordered some bender protectors on ebay. $20 still in bag
YamahaGuy-1
That is exactly what I put on mine!
lowmilevmax said:just ordered some bender protectors on ebay. $20 still in bag
what did you type in I coulndn't find them that cheap?
lowmilevmax
it was the last set. everyone else is about $40 shipped. but I first clicked on ebay motors. then parts and accesseries, then typed vmax protectors.the seller was j.l.cycles if you can contact him.
Jason
Jason
