scarffy
Sled pulls awesome. But only getting 50-60 miles per tank. Both oil and fuel. The guy I bought it from said the Carbs were just serviced.
Is this jetting or a Carb cleaning problem? Definetely smells of a rich burn. I read Mr.Vipers post on Carb Cleaning. So I might have to tackle that. Any help or info would be awesome. Thanks in advance.
hereismylife
Hello and
to the forum....
Check the faq and the tech section at the top of sled forum...
to the forum....Check the faq and the tech section at the top of sled forum...
make sure your vent line is plugged in to your air box, that sounds like what your fuel is.
on the oil, make sure the oil cable was put back together correctly. When the air box is removed, sometimes this pulls appart and needs to be slid back together.
