Basically like the title asks...
1. Is the bolt the same size?
2. Can the rubber block out of the srx's old ski be put in the vector ski and used?
Not sure on the bolt, the length will be the killer but I'm pretty sure you'll need the longer Vector bolt. The rubber SHOULD work. the bad news is you'll lose a little over an inch of ground clearance......
Yamahasrx700
97 Srx?
YAMAHIZAL700
Srx's were from 98-02 and Yes they will fit no longer bolt or anything just go to the dealer and get rubber things from that year vector. YOu can trim your srx rubber to work but its probably worn out rubber anyway. I have some on my srx and its great upgrade. handlewise and looks sweet to boot!
Thanks for the bolt/rubber info.
