01mountanmax600
- Mar 24, 2004
Any recomendations on what would be a good gearing combo for a mountain max used in the trail? Id like to get a bit more top speed but dont want to lose too much bottom end.
01mountanmax600
- Mar 24, 2004
ok thanks
01mountanmax600
- Mar 24, 2004
Say i can get 120-130 kms out of it now , around what do you think it should do with that new gearing? How big of a loss in bottom? doesnt have to be a specific answer just an estimate would be good. thanks
01mountanmax600
- Mar 24, 2004
Do you mean 2 less teeth?
..SNAKEBIT..
no you have to add teeth to the top gear to speed up!
minus teeth to gear down
01mountanmax600
- Mar 24, 2004
ok im a bit confused lol. I want to have more top speed. I thought that i had to gear up as in get a smaller sprocket/less teeth. So what should i do to get more top speed.
MountainMax
to gear up you need to increase teeth on the top gear (drive gear) or lower the number of teeth on the bottom gear (driven gear) this lowers the ratio number as people call it gearing up (more speed)
01mountanmax600
- Mar 24, 2004
ok makes sence. I think ill do it and let u all know how it makes out. But one more question. How much is a new drive gear with 2 more teeth?
MountainMax
well first you have to find out what gears you have, and what length chain you have, then find a gear, either bigger top or smaller bottom, and find out if that combination will work with your chain, if not you may need a new chain 2
01mountanmax600
- Mar 24, 2004
ok the stock gearing is 19/39 and thats whats in it now. The chain is a 68link. A stock sxr 500 has gearing of 21/39 with a 68link chain so i would think if i put a 21tooth top gear on mine it would fit with the stock chain. What do you think?
watersuper
If everything you are stating is fact, it should work ok!
MountainMax
I concur.....
01mountanmax600
- Mar 24, 2004
anyone know how much a yamaha upper gear would be?
crewchief47
Lifetime Member
http://216.37.204.202/yamaha_oem/YamahaSnow.asp?Type=13&A=201&B=30 Prices in US dollars. No part numbers. Chaincase etc is under "Track Drive 2", Item 23 is the upper gear.
http://parts.yamaha-motor.com/ This one has the part numbers in case you have less than stellar parts dude/chick at your dealer.
BlueIronRanger
- Nov 26, 2003
21 tooth should be just fine, 21/39 with 8 tooth drivers is about the same as 19/39 that I have on my SX600R with 9 tooth drivers and I top out at 100mph on radar.
01mountanmax600
- Mar 24, 2004
Ok thanks alot for all the info.
700scott
i have a 21 top gear out my 97 700 i'll sell for 10.00 +shipping if you want it
MountainMax
I have one too, same deal if you are in canada, let me know.
01mountanmax600
- Mar 24, 2004
Thanks alot guys but i already had yamaha install a brand new one . thanks anyways though.
