general carb choke plunger question
mattyg1405
east haven, CT
how does the plunger work on the choke?? in all the way/seated is off?
and when you pull the cable/plunger up it chokes it?
if this is correct if i leave a plunger in a carb that has the top pulled off from being stuck when the cable pulled through would this affect the performance after start/warm-up? the sled in question is my new to me phazer and im having problems with the carbs on this sled check out link: http://www.totallyamaha.net/forums/showthread.php?t=76774
id really appreciate any help you guys always know everything with my srx so i figured id ask as this is the busiest room here.
thanks again
Matt Goodwin
yeah im gonna make sure its down all the way and install the spring and cable end until i can get a plunger but for now i need to figure out why the hell im not getting fuel to the 1 cylinder
