praaa_5
I have a 95 Vmax 600 with oil coming our front of engine. It is spraying on the y pipe and front of the engine. I am guessing it is either the gasket or warped y pip. How do you get the bolts out without stripping the pot?
no1chevyboy
check y pipe for crack or bad gaskets
with a wrench on the 2 inners and a socket on the outer 2?
thing to do is remove the pipe and silencer by removing the springs. then the heads of the bolts are right there. nothing special, righty tighty, lefty loosey. cant recall if those had a 10mm head or a 12mm head.
the so called gaskets on those were more of a washer type insert and the y pipe used a donut between it and the pipe.
might just be loose bolts at the cylinders.
