Carbs cleaned, new plugs and new gas. First ride this season, Sled will not backshift, bogs at takeoff (tors disconnected), but will run decently up to speed once it gets going. Sled ran fine last year. Do you think I just need to clean the clutches? There is a lot of belt dust on the covers.
tedgoesfast
service clutchs inspect secondary to see if spring is in right spot.I would pull both off and give them a complete inspection and service to verify everything is ok.Have to start somewhere
I've had bad plug caps and a weak stator that bogged at low speed but ran alot better at higher rpm. Check the plugs. Are they wet with fuel?
