1999 Mm 700
JSikkMM700
Whitehall, MI
Just bought a MM 700. Had it out on the trails for about 250 miles. Sled ran great, except it doesnt idle if off choke(no how warm it gets). Secondly, 4 x's in my ride the sled stalled out bogged down and shut off. Just restarted in one pull and it was just fine. Any ideas why it would do this and any adjustments i can make to have it idle better?
It did have bender pipes and clutching...its stock otherwise.
Thank you
Lucky
CALL YOURSELF LUCKY. MOST PEOPLE WITH YOUR SITUATION END UP WITH A BURNDOWN. CLEAN THE CARBS BEFORE IT IS TAKEN OUT AGAIN. :bash: JUST SAYIN.
Cleaned the carbs, the lower jets were plugged. Also adjusted the settings from 4 to 2.5. Runs like a champ and holds an idle ;) Happy camper here!
