B Rad
Does anybody know where I can buy just one wheel and the round aluminum spacer for this kit??
Dealer was less then helpfull and I lost one.
Or if anybody has one they want to sell...
Thanks Much
Thanks Much
I just bought "One" from Pioneer Performance in NY. The cost was 1/2 of their small wheel kit, came to apprx. $47. Bruce Schrader owned.
http://pioneerperformance.net/
Heck $47 is a rip off, go to ebay and buy the whole kit for $60 shipped to ya.
B Rad
Yea for that price I'll take the other side off and sell it to somebody else and put the money towards new Hyfax's.
Thanks for the info tho!
I'll keep my eyes open for now.
mattyg1405
been on ebay, i cant find them i was wondering if you could send me a link please...fusion 69 said:Heck $47 is a rip off, go to ebay and buy the whole kit for $60 shipped to ya.
My sentiments exactly. I thought it was a little pricey.
rx1jim
You can use the small stock OEM wheel, the small wheel which is up in the tunnel. You can by this wheel from Kirk or Smart Rec Products for much less than the Yamaha part. I may have the bushing spacer for you, if not i can make one for you and send it to you. Post pictures of the wheel and spacer which you still have since there are a couple of designs for the hyfax saver wheel kits.
mattyg1405
im going to order two of these wheels what would it take to get the spacers i would need to mount them?rx1jim said:You can use the small stock OEM wheel, the small wheel which is up in the tunnel. You can by this wheel from Kirk or Smart Rec Products for much less than the Yamaha part. I may have the bushing spacer for you, if not i can make one for you and send it to you. Post pictures of the wheel and spacer which you still have since there are a couple of designs for the hyfax saver wheel kits.
rx1jim
You will need more than just the spcers to mount them. You will need the mounting block which bolt onto the rails then the bushing/spacers to mount the wheels to the spacers. If i had the time, i'd make the mounts, just swamped with too much work right now. The bushing/spacers are easy lathe work so I can make one pretty easy.
In the yamaha accessories catalog there is apart number for the spacer and I think it cost like 10.00 in the U.S YAMAHA catalog
Matty, the ebay item # is 150543622072, and he will knock some off, atleast he did me. Hope this helps
B Rad
RX1jim,
I will post the pics tonight and give you some accurate measurements with my caliper. I have an extra skid and should have those wheels. I have the block on the rail still its just the spacer/bushing (alum) which fits into the wheel.
rx1jim
Ok, post the pics and the dimensions. The spacer/bushings I have should be the right ones.
B Rad
Alright, Sorry for the delay. Battery was dead in my caliper last night and nobody had the battery in stock.
If the photo is visible I wrote down the dimensions next to the spacer. I will give them to you again.
Outside of spacer that mounts to rail block is: 31.58mm diameter X 11.75mm thick.
The dimension of the bushing that goes into the wheel is 19.99mm diameter X 11.34mm thick.
The mounting hole is 12.80mm I.D.
Going to pull off wheels from my parts skid shortly to make sure the wheels are the same. I believe they are.
Let me know what you think.
Thanks again B-rad
B Rad
http://s1216.photobucket.com/albums/dd375/srxguy009/
Maybe this worked, If not pm me your email address I am for sure that will work.
rx1jim
OK, got it. I have an extra spacer bushing. I just measured it, it measures the same as the dimensions you gave me. PM your mailing address or send it to me at jspeidel@us.ibm.com I will mail it to you on Sat., that is the earliest I can get to the post office. I'll send you the spacer, a stainless steel 1/2"-13 x 1.5" long bolt and two 1/2" stainless steel washers to retain the wheel. You should be go to go. Put some blue loctite on the bolt (not RED loctite).
rx1jim
Can you post some pictures of the engine you have in your avatar? It looks terrific!!
rx1jim
Brad,
The parts went in the mail this morning. Please let me know when you receive them!!
rx1jim
Brad,
You should have rec'd teh parts by now. Did they fit on your sled? Let me know.
B Rad
Jim,
Just got back into town last night!! Thank you soo much-it fits perfect.
I owe you one so if your ever in the UP of Michigan let me know-You've got a free place to stay!!
It's people like you that make this country a better place.
ttt
ttt
