I ve read up and down the treads pertaining to TORS and what is happen with them. My buddy's rig is firing on and off on. When you wiggle the throttle it will fire just fine, will idle fine, all until you pull the throttle open then it cuts out and dies.. Any suggestions? And also if anyone has a wiring diagram for the tors system and what the testing resistance is?
hereismylife
Hello and
to the forum.
how tight is the throttle cable? also did you try and bypass the tors?
to the forum.how tight is the throttle cable? also did you try and bypass the tors?
