crazy canuck
Hi can anyone tell me if I can use a primary off an rx-1 on a viper if I change out the internal spring, rollers, weights etc. I have a spare and would like to use it on the viper if possible.....
extremeviper
a friend did it to his viper the only dif is the spider is cut out
mopar1rules
extremeviper said:a friend did it to his viper the only dif is the spider is cut out
correct, the spider has the cutout for the flat like stock weights to have clearance, when they swing out towards full shift.
crazy canuck
Thanks for the info.
