sxviper32
got my viper put all back together and went around the yard a couple times, and started it back up today and did the same, but it smokes like a banshee! i can't see anything around me its so bad! and it won't run off the choke, and you have to keep on the gas otherwise it will die. do i just need to clean the carbs or do i have to adjust some of the carb settings? anyone have any pics of what screws to turn and what they will do? thanks for any help!!!!!
check your oil cable, sounds like it is pulled apart where you adjust it, this causes the oil pump to go full rich
hookedonblue
Yeah Betheviper Is Right. This Can Easily Happen. You Will Want To Check The Spec On The Adjustment Cable. Maybe Your Adjustment Or Sync Is Off As Well. Best Of Luck.
