Help? coolant problem
eric.s.t
Sudbury
Ok so i was wondering, im looking at a polaris, i know, not a yamaha, its not for me. So dont worry. But it looks to have some motor damage, from what the dealer says, i havent really looked at i yet. But from what they say, their is coolant in the bottom end, and the pistons have damage, the top of the pistons look good though, i have taken the head off at one point and seen no harm to them. So, my question is, what could be the problem, im guessing could be the gasket, causing to leak inside the crankcase, or a crack in the cylinder (which i hope not) also, can coolant in the case damage anything, or can i repaire the problem, and start the motor, let the coolant burn away?
Help Please?
THanks
coolent in the bottom end is not good, tends to rust,wear the bearings,and will take out the pistons and piston needle bearings.
