Adjusting power valves by hand....
SRXPete
Gogama, Ontario
Does anyone know how to adjust power valves by doing it by hand??? I am in the garage, with my pipes and exhaust things off. I know I am supposed to stick my fingers in the exhaust port, and feel if the valve is even, but not really quite sure on what to do....
Any simple step by step instruction is greatly appreciated. It is snowing like crazy and I can't go out or a ride...
Okay...I am having a hard time figuring out what "flush" means. Is it when the exhaust port is even (straight up and down) with the valve??? Or is it when you feel it flush on the angle of the valve itself (ie..move your finger on the underside of the valve and since it is on an angle, your finger flows smoothly to the exhaust port). If the end of the valve is even with the cylinder (straight up and down) then you don't feel that smooth run with your finger.
I am having the worst time trying to explain it, but I hope someone can.
