phazer flatslide jetting
mattyg1405
east haven, CT
i am waiting for my vmax 600 flatslides to get here for my phazer and in the mean time i would like to know where to start with jetting im in ct so juat a touch above sealevel i think but what size mains? pilots? thanks alot any help would be awesome can i use the jets from my stock carbs???
i know (daring) is doing the same thing i just figured a specific thread on this would be helpful...
I'm trying the same thing with mine right now, haven't run it yet but here is my starting point
47.5 pilots
150 mains
gutted airbox with cold air kit. Most people say the stock jetting for the vmax is a little rich so I went a little leaner to start with, I have a good amount of engine work done and run race fuel but I think this should be a close starting point.
Stock jetting will probably be too lean, and the pilots are a different style (cant transfer them)
I just tested mine (mod motor) with the jetting listed in my previous post and it is perfect. i would start with 47.5 pilots, one turn out on the air screws. for trail riding on pump gas 147.5-150 mains are probably pretty close. You will need to check your plugs and adjust accordingly. It also seems to run real good with the airbox gutted.
the 47.5s should work fine. I never needed to change pilots with my stock carbs when I modded the motor. Also, as long as your putting the carbs on there, replace the reeds with carbon techs. Huge difference in throttle response even on a stock sled. The stock reeds are metal and just don't work as well as the carbon fiber ones.
