Need Torque Specs for 94 VMAX 500 for the following
Patriot21
Minnesota
Chaincase cover bolts
Driveshaft bearing speedo side cover bolts
nut on the end of drive shaft that holds bearing on -speedo side
Clutch bolt
Lower gear bolt
Upper gear bolt
brake assembly bolts
rear axel in suspension bolt on bogey wheel(where the tensioners are)
These are right from the Yamaha manual:
Chaincase cover bolts 7.1 ft/lbs
Drive Sprockets 31 ft/lbs
Says: Brake Caliper Body 47 ft/lbs
Driveshaft bearing speedo side cover bolts—Just make sure they are tight, no torque given
Clutch bolts—Secondary 43 ft/lbs, Primary 87ft/lbs, take back out, retighten to 43ft/lbs
No torque for rear tensioners, you set those are tight as you need to adjust track tension. The actual back axle at the outside of the axle each side gets 54 ft/lbs.
Personally I think you are getting a little carried away wanting exact torque specs for everything, just make sure everything is tight, if you have any doubt, check them again after a short ride.
