exiter skis
snowdad4
southeast washington state
has anybody put a set of skis from a 97 or newer proaction, the plastic ones with the black saddles, on a 87 or newer exiter? besides the obvious need of some shims, are there any adverse effects?
if I was gonna do that I would use the 02 03 style because the pivot bolt is lower as well as the aluminum saddle would give you the clearance you would need for the suspension brackets
