goldminer MT
There's a Quick Stop up the road selling fuel for "sleds" only, 93 octane & no ethanol. $3.33/gal
I tried some & now my sled won't idle,loads up & basically runs like crap.
What's up? Is this fuel only for the new 4 strokes or what?
Should I siphon my tanks?
more octane makes a sled richer,without changing the jets.
if your sled was jetted for use with ethanol fuel and the jets were increased for safety, going to a real 93 octane fuel will for sure make the sled richer. You could simply try and cut the gas in the tank with some lower grade gas and see if it cleans up.
EGGMAN
I had a similar problem last year.
Check out this thread.
http://www.totallyamaha.net/forums/showthread.php?t=69751
Vmax540
mrviper700 said:more octane makes a sled richer,without changing the jets.
Interesting.... I guess I never thought of why but, I knew it would make an engine less likely to detonate.
cajones2
From what i understand (I am not an expert on the subject) is that octane controls the combustion to prevent premature detonation. When you use cheap gas with lower octane with a higher compression, the additional heat and compression may cause the charge to become less stable and potentially an early detonation resulting in a blown piston. The octane actually slows or controls the burn so the detonation will take place closer to TDC. So when you are performing mods that generate more HP, you produce more heat, and need to run a higher octane to prevent the charge from becoming unstable and detonating under the additional heat and compression before the plug fires.
EGGMAN
If your sled is not modded or requiring high octain you can actually bring down the performance by using high octain since it is not designed for it.
cajones2
Very true. I get a kick out it when i hear some say they got "race" fuel at the pump for their stock machines. Usually the younger kids in my area think they are really on to something there.
Bluemonster2
cajones2 said:Very true. I get a kick out it when i hear some say they got "race" fuel at the pump for their stock machines. Usually the younger kids in my area think they are really on to something there.
Yup, lol pretty funny, you lose power running any higher octane than you need.
goldminer MT
Thanx
Thanx Everyone, This Site Rocks...i'll Try The Addition Of Lower Octane Tomorrow.
