TPS warning light
MikeSr
Racine, Wisconsin
So, I took my carbs off to clean them before the season started, and upon start up I get the two long and one short light pattern indicating TPS (open or short circuit). Is it a matter of adjusting the throttle linkage or do I need to be looking at something else? The sled starts and runs fine, but the light comes on everytime I start it.
as dumb as it sounds, go over and make sure the connectors are plugged in good at the tps and at the airbox.
mrviper700 said:
as dumb as it sounds, go over and make sure the connectors are plugged in good at the tps and at the airbox.[/QUOTE
X2...
The connector from the carb rack to the main wiring harness can be a bit tricky to get plugged in.
Did you have the TPS off the carb rack?
HMMM. We just went through this. My light was going off so I tested it as per the manual and turns out it was junk. POOCHED. So I ordered a new one for the price of $140cdn and will install it as per the manual instructions. There's your fix.
The TPS was not removed from the carb rack. I will get a look around tomorrow and see if I didn't get something connected back up. It's possible, especially since I was pressed for time to get the thing on the trailer and out to ride on a trip.
Do our sleds have a designates tps light? I know when I start my sled, some lights flashes a few times and goes off. Never looked close to what it was. Sled runs like a champ. Curious if I should investigate and see what the flashing light is, or if every srx has a light flash a couple times upon starting
No. The temp light flashes three times when you start it up to show that all systems are a go. Anything after that is a problem code.
