High resistance in spark plug caps= low idling?
norwegian
Well-known member
norway
Will high resistance in spark plug caps cause the sled to idle a couple of hundred rpm lower? I think it's about time to replace them.
It doesn't run bad on top. 105 mph on a snow covered trail with a 1,25 track.
Clip the wires back? Does that mean like if you tighten them, and then you back them out some?
No, didn't touch anything yet.
no..he means take some wire cutters and trim about 1/4" off the ends and then install the new caps.That is what I will do when my caps come in this week.
