2000 MM700 steering column
cardude
WA
Can anybody here give me the dimension to build a steering post. I have a broken stick but it has been chopped.
I need the dimensions to build a new one. I have the bushing widths and the stop plate, handle bar mounting plate and the lower bushing with lever.
The measurements I need would be the disance between bushings so I can weld up a bolt in replacement with 12" rise over stock.
