..SNAKEBIT..
if I install a rear heat exchanger, do I need a Mountain Max cooler?
does anybody have a used one cheep?
SRX Cooler, I Believe
Thats what mine is. 136" Viper w/Maxx. Extension.
Nope!!!!
I stretched my Viper using all Yamaha parts and installed my Viper/SRX rear exchanger with only 1 small issue. I had to relocate the hole on the extension for the bleeder screw. Other than that it fit like a glove. Hope this help's ya out .
Dave
Dave
..SNAKEBIT..
I thought the SRX cooler had a Angle in it for the back corner of the tunnel?
and the Mountain Max one was flat for the extension????????????????
Snakebit, My tunnelextension came of a MSRX,so there may be a difference between it and a MM extension. And yes, my cooler is curved to fit tightly against the tunnel closeoff panel in the rear of the tunnel. I have'nt seen a MM cooler, so I don't know if they are the same or not. Sorry if I confused you, just trying to help a Yamabro out.
Dave
Dave
..SNAKEBIT..
my kit came from RICH I beleive a Mountain Performance kit?
Yes, if it is an MPI you will need a flat cooler. The dimensions are different than the Yamaha extension. I used all secondhand parts to do mine and saved quite a bit of $$$. All my parts were purchased from members here. As far as your cooler goes, call Rich or MPI and they should have specific answers to your questions. Good luck.
Dave
Dave
