Hello all, My vmax was running perfect up until I came to a stop ater a 2 mile run at about 80 mph the other day. When I started to go again my sled lost its higher speed and the RPMS were much higher than they were up until this point. Also the speed wasn't going much passed 40 to 50.
Engine runs fine with good compression and I have looked over the clutches and can't find any significant problems such as cracks, bad rollers or broken springs. Only thing I noticed is some wear around the bushing on the secondary. on the jackstand the secondary apprears to open ok.
I have also blown out the clutches with air to clean. Didn't help any.
Primary engages right around 3500 rpm which I believe is pretty close to being correct.
Any help is greatly appreciated. This is one of my first sleds and I am still learning the clutching portion of a snowmobile.
The sled is a 94 vmax 600 all stock. Belt is newer and I put new ramp shoes in earlier in the season.
Thanks in advanced for the help.
You may have a broken or really worn pri spring
