my 700 triple it has spark sometimes but sometimes not and the spark is weak!!help
yeaman
pull your cdi out and take then try the my cdi was going and thats what happend to mine
Check your flywheel and make sure the magnets are clean as a bit of rust will not let the pick up coil do its job.
venture700
sounds like the exact same problem I had when my pick up coil went bad
