Any help would be greatly appreciated
98yamsrx700
rochester ny
i have a 98 srx 700, last yr the sled ran great didnt have any problem. first time out this yr it ran great for about the first 50miles then we stopped to gas up and as i pull up to the pump the idle drope all the way down to 500 and then stalls right out. after filling up we start to take off and i smoke to belt. all the while i have to keep feathering the throttle to keep the sled running or it will stall itself out. messed with the idler screw and turned it up a lil bit and it still the rpms eventually dropped down and stalled out. then about 3 miles later we stopped to check the trail map and when starting out again i go to give it some throttle to take off and i start smoking the belt again this being the brand new belt i just put on. opened up the cowel and the clutch was moving in and out but wouldnt grab the belt to go. and at this time i had to have the idle turned up the about 3500 when stopped just to keep it running. any ideas?????i have no clue. thanks
Time to clean the clutches......... remove, inspect, and clean,,,,...........
For the primary you need a clutch puller tool....... made for the type of clutch you have....
