porkhaaks
I can NOT get my RPM down under 9000 .. tried heavier weights ,, try a white- white-white primary spring... tried changing spring position on the secondary.. WT heck ?? help????
porkhaaks
SO someone must know how to get the RPM down,,, .. might it have something to do with my secondary spring having to be tighter,,, I have a roller M P secondary ????HELP PLEASE
bolin22
Rpm=primary Backshift=secondary
How About Some Information As To What Components You Are Tuning With. What Weights? What Rivets And Where Are They Placed? What Elevation? Pipes? Gearing? Give The Guys Some Info So They Can Give You Some Ideas On What To Try. Adding Weight To The Primary Will Lower The Rpm. White Spring Is Super Congo Rx-1 Material, Not Stock Mm.
