WNR18
I have a 2000 SRX. It jetted stock(what it came with out of the box). How senstive are SRXs to jetting and neddle height? Reading the wash says I should be able to lean it out a bit.
I believe stock jets where lean out of the box. A lot of guys changedto the 01 jetting. Depends on your temp and elevation. A little rich is better then a little lean.
YAMMIEGOD3:16
DON,T. YAMMIE TRIPLES LOVE FUEL. ESPECIALLY THAT 2000. 3:16 (yammie tony)
so the 2000 SRX 700 should go up one size just to make sure no frying pistons
Is this true? going too the dealership for some jets if trueYAMMIEGOD3:16 said:DON,T. YAMMIE TRIPLES LOVE FUEL. ESPECIALLY THAT 2000. 3:16 (yammie tony)
Races 2morrow need info
YAMMIEGOD3:16
IF YA HAVE A 2000, AND YOU WILL MAKE LONG LAKE PULLS. I WOULD JETTED IT up SLIGHTLY AS A PERCAUTION. KEEP IN MIND THE 01 WAS JETTED UP AND 02 HAD THE DCS. BUT DO NOT LEAN IT. 3:16 (yammie tony)
